steve_protege said:From what I have read, here is what I have gathered....
1) 8 P.S.I would be the MAX that an auto tranny could/should handle
2) It would be very smart to upgrade the tranny with better valve bodies and a better torque converter
3) A tranny cooler would be a great idea too as well as using Red Line or Royal Purple ATX fluid
4) Drive normally until around 4th gear, then stomp on it!!!!
Am I missing anything? (Besides the ATX-->MTX conversion arguement)
About tranny coolers, where would do I begin looking for one? About how much do they cost?
steve_protege said:It would be very smart to upgrade the tranny with better valve bodies and a better torque converter
Pirana said:its really not that, but the programing is so soft that it burns the clutch, just like if in your manual tranny, you would easy the clutch out at max speed/power=you will burn the disc; everything else is ok. also good luck with a conversion, as they do involve a lot, including computer and harness.
Kooldino said:I hate to be a d1ck and argue w/ you here, but this just isn't true. If you were running a sub 10 second car, and you had 1000+hp and a CUSTOM built auto tranny, then yes, what you say is true. But if you think a STOCK P5 auto tranny is better than a STOCK P5 manual tranny, then you'd better do some research. For staters, compare your 1/4 mile times with people with the same power in a MT...you're probably about 1 second off of them.
Either way, it's good to see the research you put into rebuilding your tranny, and thanks for letting us all know.
