Autocross: Bentley Continental Supersports vs. Miata
TinmanMS6
2012 Subaru WRX
What’s faster? A Mazda MX-5 Miata or a Bentley Continental Supersports? Crazy question? Maybe. One features a normally aspirated inline-4, the other, a twin-turbo W-12. On the surface, this is brutally unfair. There’s no question the Bentley is faster and infinitely more civilized on the open road, but on a tight and twisty autocross, the Miata will dominate. Or will it?
That’s what Road Test Editor Jonathan Elfalan and Detroit Editor Shaun Bailey set out to learn. In the discussion stage, Bailey announced that he, in the Bentley, could take Jonathan in the Miata. This affront to Jonathan’s driving ability was too much to bear, so we set up an autocross course on a deserted local runway. Who would win this duel? Let’s find out.
Bailey in the Bentley
As a staff member of R&T for almost 10 years, I have a good grasp of what it takes to go fast, and the Bentley’s got it. I’ve always been a fan of lightweight cars with good driving dynamics, but when it comes to fast laps, I’m aware the Miata is short on power. The Supersports, though, is Bentley’s best performer, a car whose 204-mph top speed makes it more appropriate for the Mulsanne Straight than an autocross. But I hedged my bets; even if I lost, I would still get to spend my time in the lap of luxury that is the quilted leather driver’s seat. Second place in a Bentley is still better than first in the Miata in my mind.
As I’ve learned, weight isn’t the biggest hurdle to overcome for short sprints. The Supersports accounts for its 2.5 tons with all-wheel drive, sticky Pirelli P Zero tires, carbon-ceramic brakes and 621 horsepower. Its twin-turbo W-12 can push it to 60 mph in 3.6 seconds. Yeah, I know it will understeer like mad in the tight stuff, but I think I can get enough out of it to beat Jonathan in the Miata. I’ll just have to do it quickly, as moving this much mass will surely wreck the tires and heat-soak the engine after a few laps. If there’s going to be a fast lap time, it’ll happen while the car is fresh.
We tried to make the track fair for both cars, but the 4000-foot layout ended up being tighter than anticipated, making the Bentley exhibit steady state understeer much of the time. It took a lot of patience to make the wide arcs necessary to minimize understeer in this powerful beast. The result? Using up lots of track and agonizingly slow apex speeds. Even still, after seven laps I was confident the Bentley would win; its ability to launch forward whenever the track opened up left me with a half-second lead over Jonathan, who was on his ninth run. But the Bentley was done; the turbos were hot and the tires greasy. I’d have to let it cool down before it could set another time. The Miata, though, never worked up a sweat. It could likely run for hours and just need a good wax at the end of the day. I should have made Jonathan stop running at this point.
A Bentley Continental Supersports versus a Mazda MX-5 Miata? I know what you’re thinking, but let’s back the truck up here a moment. Sure the Bentley has it all: power, grip, all-wheel drive and luxury, but in this case “all” comes with a whole load of mass; 2 and a half tons, if you’re asking. So when Bailey challenged me to a duel, it took me a nanosecond to know that I would soon be crushing his $275K-plus ride, not to mention his ego. And I’d be doing it in car that many people see as a girly car. Well, this “girly car” also happens to have a torquey engine, close-ratio transmission, deceivingly sticky Bridgestone Potenza RE050A tires, oh, and the sport package Bailey forgot about, which adds a limited-slip differential and Bilstein sport suspension. I’m going to be dancing circles around Bailey and his Bentley as they plow their way into imminent humiliation.
On the day of the duel, we laid out a track that would be relatively fair. Half of the track would favor power and exit speed, the other half, size and maneuverability. We took a couple of orientation runs—a good thing because I found the sea of arbitrarily placed cones a bit confusing. To keep things fair, I went out in the Bentley, and Bailey in the Miata. Upon swapping keys, Bailey was nearly ready to concede before the match began—perhaps I exaggerated the Bentley’s understeer a bit...
And then came a rude awakening. Amidst all the tire squealing and large turning radii, the Bentley was frighteningly quick! This couldn’t be happening! Bailey looked on with a smug face as I frantically began over-driving, because it felt fast. Then, however, the laws of physics kicked in—the Bentley hit a heat-soaked plateau and couldn’t go any faster.
The window of opportunity had opened—a window that only a small car could fit through, so I calmed my nerves and steadied my inputs on my last run. Pow! The Bentley was dead. I tip my hat to Shaun for giving it a good run, which certainly upped the fun. A close race always makes for a good race. At the end of the day I believe we can all walk away with some truths; that “light” can overpower “might,” and there are some arguments best solved with a showdown, on the track.
Bailey in the Bentley: 73:50 seconds (max speed on course 58.9 mph)
Jonathan in the Miata: 73:30 seconds (max speed on course 57.1 mph)
In the picture it shows a hardtop MX-5... but it doesn't say which they used... I mean I'm guessing it was the hardtop but... then my question is why?
hard top would only have added 37kg to the car, the weight of a medium child hardly makes a difference. if you had one of the steelers linemans in the seat you might have a weight problem.
not too surprized, if you throw the cost of a house into a car i'd hope it can at least keep up with a miata.
Oh I know the weight doesn't really have an effect on the performance of the MX-5, I was just questioning why they had the hard top and not the typical Miata...
