Auto Window Switches
Protege5
Easy Question:
I have access to a few of the auto up/down switches at a junk yard that are for the drivers window. Could is possibly as easy as swapping switches for the other 3 to have them be auto as well? I haven't taken it apart yet but figured i'd ask first.
It could be worth a shot if there is enough room for the switch (I'd assume it's bigger than the non auto ones) under the switch panel.
I would love to do this too! Especially if someone could figure out how to do auto-up as well. I was driving an 09 Jetta last week and loved that one click could do both up and down all the way. Although honestly, I don't think it'd be just the switch. You'd probs need capacitors and relays for each switch.
No you can't do it it's not as simple as changing a switch. the circuit board is designed so that only the driver side window is auto up and down the other ones can't. I have already taken apart the switches and its a pita just to disassemble the thing.
Figured as much, thanks for the reply and saving me some work!
I added auto up and down for all 4 windows to my 2Way alarm module, so if needed i just hold the button down while driving and it drops all 4 at once and when i get to where I'm going i can close them at once. Also works great after work since i can drop the windows while walking to the car. The systems are available to do 2 or 4 windows in the aftermarket electronic world.
There is some kits for this on ebay, but from what I have seen, it takes a lot of work in the door to make it happen. I would love it too...I hate just the driver's window auto down!
IIRC ( been 5 years now since install) we only had to work with 8 wires for the windows and the 3 to the alarm module. They are DEI units in my drivers door.
bikingpro, could I bother you for a link to where it is you did the auto up/down function with the remote? Its a nice feature to have on my dads Altima. If it's too much of a hassle to find it, I'll give it a search. I would assume ZapWizard might have a tutorial but I'm not entirely sure...
there is no link that i know of, i used the aux 1/2 on my compustar 2way to control the window modules i bought from DEI. im sure if you have an aftermarket alarm and have aux you can easily wire them in.
http://www.directed.com/guides/manuals/ig/accessories/N530T_1-00.pdf
newer version of my unit now allows one touch for the windows that do not have it
http://www.directedstore.com/cgi-bi...=all&searchstart=30&template=PDGCommTemplates
