Silver Ecstasy
- 11 MS3 Sport
When I first turn my HID's on, I noticed (with the engine off) that the projectors would both adjust independently and randomly. Try it once for yourself! Don't turn the car on, but fire up the HID's and go to your headlamps. You can hear the little servo motors adjusting the projector up or down.
Makes me wonder why? You'd think if you adjusted the leveling on the dash to "0" then it would stay at "0" and not change right? This leads me to believe that the headlights still level based on elevation and the road too. Because, I also walked across the front of the car a few times and they made independent minor changes. I didn't get to pay close enough attention of the beam pattern was moving up or down by much because they were such small adjustments, but they do move slightly.
This could also be the reason why I noticed the pattern sometimes shake under hard bumps, because the headlight assembly sits pretty solid in it's place.
Comments!
Comments!
