Peloton : 2009 Mazda 5, Grand Touring Oct 26, 2012 #1 Does anyone know what type of bulb this is? Mine burnt out and I can't find the bulb type anywhere.
T the_saint 50% borikn : OG Mazda5 Nov 20, 2012 #2 I'm in the same boat as you. It sure is a strange looking bulb/base, that's for sure.
J jason10phan Member : Mazda 5 Dec 9, 2012 #3 Sorry guys ,i also did this. The only place i found this ,is at the dealer. They are small and long ie( half inch long ). Hope this help.
R rat240 Member : 2010 mazda5 Dec 10, 2012 #4 I believe they use a t3 bulb http://minkara.carview.co.jp/en/userid/1529031/car/1128778/2016539/note.aspx http://www.ebay.com/itm/170778525550?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
N njaremka Wiggity-Wack-O-Tack Contributor : 2019 Mini F60 JCW Dec 10, 2012 #5 stock part number for the bulbs is CC51-61-C95 dimensions match a neowedge T3 pretty close, but the stock bulb has more length to it.
T the_saint 50% borikn : OG Mazda5 Dec 10, 2012 #6 njaremka said: stock part number for the bulbs is CC51-61-C95 dimensions match a neowedge T3 pretty close, but the stock bulb has more length to it. Click to expand... Awesome! Thanks. I found this site that actually has the tall base bulbs http://autolumination.com/74.htm but they're T4, which apparently is 10mm across the base, whereas the T3 is 8mm across the base. I'll pull mine apart and measure.
N njaremka Wiggity-Wack-O-Tack Contributor : 2019 Mini F60 JCW Dec 10, 2012 #7 trust me, the stock bulbs have a T3 base - i have one sitting in front of me. base diameter is 8.0mm, height is 23mm, bulb diameter is 5mm.
