joshritger
- 2007 Galaxy Grey Mazda 3 S Hatchback (a.k.a. DILLA)
I have had off and on luck with my car in regards to getting it to shift decent. The past three days here have been in the upper 90's and the car seemed to shift horribly in the afternoon on the way home from work. In the morning the temp was around 70 and the car seemed to shift ok. Is there a big benefit in cooling the tranny fluid down with an extra cooler? I was reading reports that the coolers can help smooth out the shifting and reduce the lag caused by thin tranny fluid.
Background: 07 M3 Hatch, 30,000 miles
Transmission was replaced at around 15,000 miles because of inconsistent shifting/pressure loss somewhere. New transmission shifts good sometimes, other times it is horrible. Sometimes it does not like to down shift also.
I found this cooler that isn't overly expensive and had good reviews:
B&M SuperCooler for Automatic Transmissions
Any other suggestions would be great.
Thanks,
Josh
Thanks,
Josh
