Wow, that was alot. I'll be honest with you, I don't know anything about half the stuff you just rattled off. But to answer your question - yeah, I'm using my stock fuel rail, and stock injectors at the moment. I've read that at only 6psi I don't really need to go any larger.
One thing that I wish I did was seperate the work. In other words I wish I had done the Doc B pump/oil filter reloc./ext. PRV/oil pressure gauge seperately. That way I could diagnose any problems that may have occured while redoing the timing, without having all of the turbo stuff to make things more complicated. If your install plan allows you to easily do this, I'd recommend it.
GLW your build. Feel free to hit me up with any questions, although you sound like you'd be able to answer anything that I could, lol.
