ATF Change - Remarks from BobIsTheOilGuy site - please read.
About Mazda SkyActiv transmissions:
https://mazda.oemdtc.com/725/atf-fz...e-6-speed-automatic-transaxle-2012-2016-mazda
"SKYACTIV-DRIVE FW6A-EL AT with “ATF-FZ” is “filled for life” (no change intervals for ATF required) and flushing is not recommended as part of service maintenance. There are no oil cooler lines and the replacement SKYACTIV-DRIVE FW6A-EL AT will come with a new oil cooler, which is mounted directly to the case. If repair or AT replacement is necessary, use only “ATF-FZ” to fill the AT."
Sent from my ASUS_Z012D using Tapatalk
