ARP confirms....
Hand tight on the Stud....
Then Tighten to the required torque SPec.
Sorry..But ARP has been doing this a long time..I trust their Tech dept.
They Said Tecnically...1-3 ft./Lbs. on the stud...then Torque the nuts to the Spec in the box....but hand tight would suffice just fine.
I believe thats the Downright end of that subject right there.
No need for arguements.
not arguing or anything just a simple question lol, if the stock studs are a long bolt and torqued down why wouldn't you torque the studs and the bolts on the arp .
Don't really catch get that.(smash)
See..I agree...because the Nut and Stud will only Turn until the Required Torque Seting is reached then "Click"
Nut and stud are then at the required torque setting.
Use whatever spec is included in the packaging. As you see, there are two different values depending on whether you use the ARP lube or motor oil.
Lube the top threads of the stud where the nut will thread on, not where they go into the block. Snug the studs with a t-handle into the block. Lay head gasket onto motor and place cylinder head on top. Lube washers and nuts, snug them in the factory spec'd rotation onto the studs. Then tq them to half final value, then fully torque them.
DO NOT torque the studs and do not use Mazda fastener specs. The spec sheet included with the ARPs is fastener specific and sometimes application specific(ie. iron block/alum head or alum block/alum head).Do not double nut, you shouldn't have any extra fasteners.
The included specs from ARP are for the nuts only. In the dozens of motors I've assembled using ARP head studs, not once have the studs been torqued and not one customer had a problem. The owner of the shop has also done it this way for more years than I can count.
EDIT- I don't see how you can torque a stud with a 5mm allen socket to 90ftlbs w/o damaging it. If the stud needed to be torqued ARP would make the tip hexagonal to allow for such a high torque.
DO NOT USE FACTORY TORQUE SPECS ON THE NUTS! The factory bolts are torque to yield, so it's like 30 ft lbs plus 180* The ARP bolts don't stretch like the stock ones, so they need to be torqued differently. Do them in sequence, and step the torque values too to keep from pinching your head gasket.
The stud should turn a little. ARP includes different torque values depending on the lubricant used and the extra stud movement is accounted for. The nut gives you all the clamping force you need. Why would you torque a stud? Do you torque studs on any other application?
(thought)
The reason you don't torque the stud is you are twisting the fastener horizontally when it should only be stressed vertically.
You negate one of the benefits of using a stud vs a head bolt by torquing the stud. Also, I'd like to see someone try and torque that stud 90 ft lbs.
did you not read the sheet carefully? it says at the end of it to follow the manufacturer's torque sequence... that tells you a lot that whatever is shown on that sheet IS what you need to do!Just a quick question....
The paperwork that came with my head studs lists specified torque installation values for installing the studs...but it is a general Spec sheet..not application (CAR) Specific.
Shuld I use their torque values or should I use Mazdas for the head bolts?
I thought these were supposed to be installed to a "Torque Angle"?
Or is that just the Main Studs?
Thanks in advance for the answers guys.
<!-- / message --><!-- MOD: some sig thing --><!-- /MOD: some sig thing --><!-- sig -->
what did you do? toss the ARP instruction sheet in the trash when you opened the box or did the wind blow it away?I've torqued my studs themselves (before head was on) to 90 lb ft.
Last I checked..I asked about torque Values..nothing about sequence.did you not read the sheet carefully? it says at the end of it to follow the manufacturer's torque sequence... that tells you a lot that whatever is shown on that sheet IS what you need to do!
I thought you knew all these things about cars to know something as simple as this! nevermind
I guess now we know why you said you had problems with head studs and why they "suck" and instead should be using the stock head bolts instead![]()
like I said... whatever is shown on the sheet is what you need to do... you follow what it says to the T and you'll be fineLast I checked..I asked about torque Values..nothing about sequence.
But that right..your the almighty ass...only you know it all.
And yes..I did read it..and there is enough BS info that doesn't apply on one of their sheets that it would make the guy who wrote it question what to do and what SPecs to use.
But thanks again for your wonderful input..Once again..your still my favorite.
BTW....There is absolutley nothing wrong with verifying your info and thoughts BEFORE doing something so as not to make an error.
ok, my bad.... I confused you with brian MP5T... some how I'm still doing it... you both are from canada, have a P5 and turbo'd them... no, I never read anything from MPNick about head studs
