are SRI maps available for Cobb AP
if you have a cobb sri, as that is really the only sri i know of unless you went custom.
true i did forget the nano just came out, but i guess the question was what kind of sri is he running.
yeah i guess you could say the filter has something to do, because i'm sure a cheap filter from autozone would let dirt by.
Or like the time I once saw a foam "high performace" eBay HKS look alike filter on a turbo civic. His motor blew from a combination of things, but one of them was the filter coming apart and getting sucked inside his engine!!
agreed, but those issues are completely separate from the tuning aspect... Dr.D made it seem like the filter was responsible for the sensor readings you will see using a given filter moreso than than the MAF housing itself.... which is incorrect.
+1 to mdogg.
to further explination for some who want more of an understanding. the only thing a filter will hurt is the flow across the maf, it will not change its readings. now a different size maf housing that isn't the same as stock will cause different readings. for instance if your maf housing is smaller than stock you will run rich and if its larger you'll run lean. problem with some aftermarket intakes is they use larger than stock maf housings where as cobb and cp-e use the stock size. i also think fujita is close to stock as well. pipe bends will also have an affect on the reading because bends in certain places can cause turbulent air and that can skew the maf reading as well.
so is anybody running either the cp-e nano or the cobb sri.
im leaning towards a sri as opposed to a cai to get more power. how do either of the 2 run?
i run the ms3 cobb sri on my car and have been doing so for quite some time now and have never had any problems. i believe the one for the ms6 is shipping within the next month or so.
i dont know about everyonr else but SU has started shipping the cobb sri for the ms6 mine will the shipped this friday.
__________________
thats exacctly what i wanted to hear. im ready to order mine than. have you spoken to SU or Cobb. are maps available. thats if u have AP or not....
i spoke with chris from SU, i believe there are a few maps for the SRI. as far as i know now they are trying to fufill the back orders first, i had mine reserved since june.
