4 49er Member : 2003 Mazda Protege Jan 5, 2017 #1 I already know it's the head gasket. I've never worked on a P5 other than standard fluid changes, brakes, etc... so is there anything that tends to be troublesome on this model or that I should know before attempting it? Thank you.
J Jackie chan Member : Pro5 Jan 5, 2017 #2 Pretty straight forward. Sent from my SM-G900T using Tapatalk
M MrGiggles : Protege5 Jan 5, 2017 #3 Check the VICS and VTCS butterflies while the intake is off, make sure the screws are tight, delete if you choose.
J Jackie chan Member : Pro5 Jan 5, 2017 #4 MrGiggles said: Check the VICS and VTCS butterflies while the intake is off, make sure the screws are tight, delete if you choose. Click to expand... Good one, might wanna replace your waterpump and timing stuff too while you have it all apart. Clean egr too.
N NaturalFlavored : Mazda P5 Jan 5, 2017 #6 Don't forget the rear motor mount. Will be easy with everything out of the way.
P PSUENGR Member : 2003.5 MSP Jan 6, 2017 #7 Looks like a ton of fun. Report back on how it goes Sent from my SM-N910P using Tapatalk
