anyone tried fogs in the 2003.5's yet?
not that you can really see without getting really close. I took the black plastic grating that used to be there and cut it so that the bracket and foglight fit into it. So it looks a ll nice instead of the open area all around it.
oh ok..
but if u completely removed that little grill, would the fogs sit further back?
haha, deer are easy (from what i hear), they stand in the road!!, kangaroos will jump out in front of your car, i mounted some driving lights on mine to cope with the damn things, so i geta good head up, and the drivers also light up a patch like fogs, and to the sides... they are the best things ever!!
here its illegal to drive with them on anyway, but everyone does.....
those rounds look good in there, how about mounting it to the side of the hole???
I don't think they look too bad - but does anyone know if we could use a smaller fog that will at least sit flush or even sit back a little? Maybe something other than Angel Eyes? Maybe something even a little smaller?
Nice work tbl! Thanks for the pics!
well i dont think fog lights would blind you, simply because their range is outwards and not straight forward like your head lights...
wow.. i like
did u have to remove the lip first?
how tough was it? i don't wanna have to go to a shop and pay for installation
if i were to do it again it would only take me like 30 min. You don't need to remove anything. All I did was attach the bracket to the top of the hole (as far back as it could go. Wiring is cake you can funnel the wires down the hole where the injen cai goes. The hardest part of the install (after i figured stuff out) was getting the 3 wires for the switch through the grommit in the firewall. If you have any other questions post them here or drop me an email and i will do my best to answer
how about die!
have a sense of humor =D
i might get around too it, but i lack a digital camera to take pictures step by step. and i lack time to describe everything! its quite simple if you just give it a shot it should be no problem.
hey where did you put your trigger wires? also where did you locate the relay? i was gonna put mine in the relay box, but ran out of wire (remember i have to cross sides....)
i bundeled up in between the cai and the headlights. Just some electrical tape. i don't know what trigger wires are! if you mean the switch, i put it next to the dimmer switch using one of the blanks (i cut out a box for the switch that came with the angel eyes).
oops, i should of said, what did you run your trigger wire (switching) off?
did you have the fog lamp wires behind that dimmer switch???????
