Has anyone tried installing Mass Loaded Vinyl in their Mazda 5 front doors. I'm thinking about it, but wasn't sure if I should try to put the MLV between the plastic inner skin and the door, or between the panel and the plastic inner skin. Both of the locations appear to be a pain to do. There are a lot of cables, etc between the plastic inner skin and the door. The plastic inner skin appears to be a pain to fully remove as there are a lot of wiring that is attached to the plastic skin. On the other hand, the interface between the door panel and plastic inner skin is not very flat, which would make it difficult to hang MLV on it.
I'm trying to get a bit more noise reduction from the outside. My understanding is the MLV + decoupling foam is the best way to do this. I've already put Fatmat on the outer skin of the door.
