Anyone have clutch issue on 1-2 shift?
break in...
Break in is about the first 2 minutes the engine is running.
Rings seat almost immediatly, although they will hone down a bit and the bearings will loosen, but hard driving does not effect that.
The whole vary rpm thing is from the 60's. Before heat treated camshafts and engine parts you were told to go through a procedure, the point of this was to heat treat the parts, mostly the camshaft. If you did not the cam would remain 'soft' and you'd slowly grind the lobes down.
Its everyones own choice, but I have alot of experience in the area, never had a single problem what so ever and never expect to. I personally think a hard driven car when new tends to run better, probably no truth to it but I've run every single vehicle I've own to the limit as soon as I left the lot.
We built the motor in the Camaro, strapped it to the dyno and made 26 consecutive full pulls at over 650hp, 14K miles later it still runs like a top and uses nothing.
My original Camaro motor I took the car right out of the dealer and upto 150 after a few miles to make sure everything was together, 1 week and 340 miles later it went 107 at the track and that motor ran like a top making 450HP NA on heads/cam and 550 on N20 for almost 22K miles before I sprayed it a little too hard and it finally gave up a piston.
You guys do more 'damage' to the motor changing out the oil sooner than the recommended time since there is an additive in factory oil.
When we do engine simulation tests at work, bolt it together, put it on the dyno, run WOT simulations and hard testing till 100K miles or failure, we do not break in procedure at all. That is how they are designed out of the factory to run, all failures and their fixes are addressed from the point of 100 percent usage from the time the engine starts, minus the time to come upto operating temp.
While I do not have a P5, I have a MP3, so basically the same thing. I've probably done about 3 grinds from 1st into 2nd in my first year of owning my MP3. However, in the last month, this has happened three additional times at high RPMs! I also notice now that 1st to 2nd is quite jerky, especially on a cold start (even when its 80F + outside) --- I will get up to about 4000 rpms and shift into 2nd, and let out slightly, and it will kind of jerk rapidly. Never used to do this. The grinds are caused when I shift above 5000 rpms.
NoOne, have you gotten a fix for this issue yet? I'll probably bring this up with the dealer when I go in for my semi-monthly bushing replacement :rolleyes: ...
Chris
I guess I have the opposite problem.
On any 1 to 2 shift at higher RPM ranges, I have to concentrate to keep my foot almost off the clutch pedal completely, as any pressure there at all begins to release the clutch a little too soon on my car.
I have a little trouble with it, as the clutch and shifter are BOTH much different from my Miata - Yes, I got the B&M short throw shifter (ordered it the second day I had the car).
That said, I usually come out of first at about 5K, as staying there any longer seems counterproductive - Not like the Miata at all, which pulls to 6500 rpm VERY strong, which puts me at 4000 in the next gear, again, VERY strong.
Different cars with different strengths - I really enjoy driving them both, for different reasons.
Don
I only have 800 miles on my car, and I noticed the problem that these people are talking about from the second day of having the car.
I usually run 1st to 4000rpm, and i like to shift very quickly. the smoothness and quickness of the pro5 shifter is one reason i loved it when i test drove it. When i throw the shifter into second, it always kinda clunks in, no matter what rpm i shift from. I don't have this problem at all in other gears.
Also, just trying to shift into 1st from a standstill i'm always met with this resistance from the shifter before it actually goes into gear. It's always like "ka-klunk" before it goes in.
After reading all the posts, I now know that this problem is not just me. I'm gonna head to the dealer soon so they can look at this. fortunately they'll give you a free rental car whenever it's getting fixed (d/t our warranty).
'03 pro5 midnite blue
