any sulotion 2 usd 2 aux in my audio factory
zo6om
hi again
i have 2 Aux
first: for audio link usb
sac:for dvd changer
this two aux have same plug connecter
in mazda 6 audio factory have only one space 2 use one aux connecter in the rear audio factory
how i can use the two Aux at have only one input aux in audio factory ???
You could use an auxmod for your MP3 player, it connects to where a cassette deck/MD would go. This way you can use both CD changer port and the cassette deck port.
Alternatively, if you have some soldering abilities and electronics knowledge, just cut off one connector, splice the wires of the other connector and join both cables together onto one connector. Also put a multipole switch in the place where the wires split to select between two audio sources.
thnk u for reply
do u mean connect the 2 cable for the two deivce with both and put switch between the 2 unit 2 select audio unit (where put the switch i mean better used the switch for audio wire for both or just put switch for both ground....? 2 just select by switch one of them unit 2 work ))
