Any photographers in here?
yay for macro
that upc code thing was already proven to be fake last week :)
so many rumors I give up on watching, I just got a 30D a while ago so I doubt I will be going 40D unless there is some huge upgrade which i doubt it will be
come on 5D replacement then we will be talking :)
LOL... sorry.... i wanted to believe it!
well, i posted in the other forum, but the 30D wasn't significant enough for me to get. so i got this bad boy (sorry about the crappy cell phone pic quality):
ok I made up my mind, the 30D (which I had for less than 1 month) is leaving and I am getting the 40D :D the ethernet port, usb port for a HD, auto iso, enhanced AF, digic III, liveview + silent mode, 3" screen + slightly bigger viewfinder, 14bit pics & 10MP
pretty good upgrade I think
full specs, good chance this will be official tomorrow :D
* 10.1-megapixel CMOS sensor captures enough detail for photo-quality poster-size prints
* Large 3.0-inch LCD display with enhanced Live View and broadened color gamut
* 6.5 frame-per-second continuous shooting capability (for bursts of up to 75 Large/Fine JPEGs or 17 RAW images)
* sRAW mode; 35-zone metering system; integrated Self-Cleaning Sensor Unit
* Powered by BP-511A, BP-511, or BP-512 lithium-ion battery pack; stores images on CF cards
Technical Details
* Resolution: Approximately 10.1 million effective pixels (total pixels: approximately 10.5 million)
* Recording pixels: 3888 x 2592
* Sensor type: CMOS sensor, with primary R-G-B filtration
* Sensor size: 22.2 x 14.8 millimeters
* Pixel size: 5.7 microns square
* Lens focal length factor: 1.6x
* Sensor dust removal: EOS Integrated Cleaning System; active removal of dust by vibrating front low-pass filter; automatic removal of dust spots, in Canon Digital Photo Professional software (v. 3.1 or higher)
* Maximum frames per second: 6.5 frames per second (fps) at full resolution
* Maximum number of frames / burst: JPEG: 75; RAW: 17
* Shutter speeds: 30 seconds to 1/8000, plus Bulb (1/3 or 1/2-step increments)
* Flash sync speed: Up to 1/250, with EX-series Speedlites
* Anticipated shutter durability: 100,000 exposures, based on Canon test methods
* Computer interface: USB 2.0 (Hi-speed)
* Image recording storage media: CompactFlash (CF) cards (type I or II, including Microdrives)
* Card compatibility: "FAT32" compatible--OK for cards over 2GB
* Image format options: JPEG (choice of "Fine" or "Normal" compression); RAW (Canon .CR2 RAW file format); RAW + JPEG (any JPEG file size available; JPEG file written as separate file)
* Analog to digital conversion: 14 bits per channel (16,382 separate tones from brightest to darkest, for each channel)
* Resolution options: "Large"--3888 x 2592 (approximately 10.1 million pixels); "Medium"--2816 x 1880 (approximately 5.3 million pixels); "Small"--1936 x 1288 (approximately 2.5 million pixels)
* File numbering: sRGB color space: IMG_0001.JPG or IMG_0001.CR2; Adobe 1998 RGB color space: first character is always underscore (_)
* Folders: Automatically created for image storage; new folder can be user-created with "Manual Reset" function; folders cannot be freely selected on memory card by the photographer
* Highlight tone priority: Expands tonal range of bright highlights by about one stop; ISO range limited to 200 to 1600; activated by C.Fn II-3-1
* Data verification: "Original Image Data" can be appended to each image via Custom Function IV-6-1; requires optional Canon Original Data Security Kit OSK-E3 to check authenticity
* Live View viewing options: Camera's LCD monitor; computer monitor, via USB; computer monitor, via wireless transmitter WFT-E3A
* Manual focus: Viewed on LCD monitor, with option to magnify focus area 5x or 10x
* Autofocus: Possible--C.Fn III-6-1 active, press AF On button; mirror drops down temporarily while AF On button is pressed, allowing AF to function
* Silent mode Live View shoot: Mode 1: First shutter curtain remains open; shooting up to 6.5 fps possible; Mode 2: Quieter option; 2nd shutter curtain doesn't close until user's finger is taken off shutter button
* Accessory wireless transmitter: Canon WFT-E3A (optional, dedicated wireless transmitter)
* Attachment to camera: Attaches to base of camera; totally integrated with EOS 40D's design
* Wireless transfer methods: 802.11b or 802.11g; link speed: approximately 11 megabits/second (802.11b) or 54 megabits/second (802.11g)
* Connection method: Infrastructure or Ad Hoc (802.11g functions in Ad Hoc mode)
* Maximum wireless distance: Approximately 490 feet (150 meters), if "receiver" has its own antenna (depends on environment)
* Wireless channels: 11 (in North American market)
* Ethernet (wired) transfer: Yes; Ethernet 100Base-TX (maximum distance approximately 1,000 feet); link speed: approximately 100 megabits/second
* Transfer options: 1. FTP mode (images sent to folder on host computer); 2. PTP mode (remote control of camera possible from computer); 3. HTTP mode (view camera's files using web browser; remote firing of camera possible)
* Security options: Encryption: WEP or TKIP/AES; authentication: open system, WPA-PSK, or WPA2-PSK
* USB "host" capability: Plug compatible USB devices into WFT-E2A, for use with the EOS 40D; GPS devices (write GPS time, coordinates, and altitude info into each file's EXIF info); external hard drive (connect compact external USB hard drive, and write files directly from camera to the hard drive as if it's an additional memory card)
* LCD monitor: 3.0-inch (diagonal) TFT color; approximately 100% coverage; approximately 230,000 pixels on monitor; approximately 140 degrees viewing angle
* LCD monitor brightness: Adjustable in 7 levels (via Menu)
* Video-out: Yes (to standard TV monitor); NTSC or PAL, selectable on Menu
* Number of AF points: Nine, all cross-type AF points
* Center AF point: Unique hybrid cross-type AF point; world's first high-precision AF point with both horizontal and vertical high-precision; additional standard precision, cross-type sensors for lenses from f2.8 to f5.6
* AF point selection: 1. Manual AF point selection via 9-way multi-controller on back of camera; 2. automatic AF point selection
* AF activation: Shutter button, or new AF On button at back of camera
* AF modes: One-Shot AF (for stationary subjects); AI Servo AF (for tracking moving subjects); AI Focus AF (auto selection of One-Shot or AI Servo AF)
* AF sensor: Entirely new Canon CMOS AF sensor
* AF sensitivity range: EV -0.5 to 18 (at 73 degrees F / 23 degrees C, ISO 100)
* Shutter speeds: 30 seconds to 1/8000 second, plus Bulb (1/3 or 1/2-step increments); x-sync at 1/250
* ISO range: 100 to 1600, in 1/3-step or full-stop increments; ISO can be expanded to 3200 via C.Fn I-3-1
* Auto ISO: Can be set in any exposure mode, including P, Tv, Av, and M; ISO usually based at 400; typical auto range is 100 to 800, depending on conditions; manual exposure mode: auto ISO fixed at 400
* Exposure modes: Manual, Aperture-priority (Av), Shutter-priority (Tv), Program AE
* Full-auto modes: Green Zone, Portrait, Landscape, Close-up, Action, Night Portrait, Flash Off
* Metering: 35-zone metering sensor; Evaluative metering (linked to all AF points); Center-weighted metering; Partial metering; Spot metering at center of picture (approximately 3.5% of picture area)
* Metering range: EV 0 to 20 (all patterns, at normal temperatures)
* Exposure compensation: Possible in P, Tv, Av, and A-DEP exposure modes; +/- up to two stops, in 1/2 or 1/3-stop increments (via Quick Control Dial)
* Autoexposure bracketing: Possible in P, Tv, Av, M, and A-DEP exposure modes; +/- up to two stops, in 1/2 or 1/3-stop increments
* Compatible flashes: All Canon EX-series Speedlites, including new Speedlite 580EX II
* Camera menu sets flash: Yes (580EX II only, as of August 2007)
* E-TTL II flash metering: Flash metering not linked to active AF point; distance from compatible EF lenses now used; entire metering area can be averaged using Custom Function 14-1
* Modeling flash: 1-second burst of flash possible at 70Hz when depth-of-field preview button is pressed (580EX/EX II, 550EX, 420EX, MR-14EX, MT-24EX, and Speedlite transmitter only)
* Wireless E-TTL: Fully compatible, including ratio setting over six-stop range
* Flash exposure compensation: Up to +/- 2 stops can be set on camera body (can also be set on compatible Speedlites)
* Built-in flash: Covers lenses as wide as 17mm (27mm equivalent); Guide Number 43 (feet)/13 (meters), ISO 100
* Viewfinder focus screen: New interchangeable "Ef" series focusing screens; standard screen: Ef-A--precision matte screen very similar to EOS 30D; optional Ef-D screen--precision matte with grid lines; optional Ef-S screen--Super precision matte (superior manual focusing with fast lenses, f1.8 to f2.
* Viewfinder display: Similar to EOS 30D; new: ISO is always displayed; new: B/W shooting mode icon; new: maximum burst available now two digits
* Dioptric adjustment: User-set from -3.0 to +1.0 (range can be extended using optional Canon dioptric Lens E, plus rubber frame Eb)
* Mirror lock-up: Possible via Custom Function III-6-1
* Eyepiece shutter: None (cover is provided on included strap)
* Color space: Standard sRGB or Adobe 1998 RGB (separate setting on Menu)
* White Balance: Auto; Pre-set (Daylight, Shade, Cloudy, Tungsten, Fluorescent, Flash); color temperature (set by user from 2500K to 10,000K in 100K increments); custom (shoot white object or 18% gray card, base WB on that neutral object)
* White Balance correction: Fine-tuning of overall color, in any white balance mode; amber–blue correction, in 9 steps; magenta–green correction, in 9 steps; set on graph on LCD monitor, using 9-way controller; both types of correction can be combined
* White Balance bracketing: Three separate files written with a single click of the shutter; can be varied in the amber–blue direction, or the magenta–green direction; can be adjusted up to +/- 15 mireds (equivalent to 3 steps on the 9-step adjust scale); can be combined with standard auto exposure bracketing (9 files written to CF card)
* Picture style: Extensive range of settings for user to tailor color, contrast, sharpness, etc. to their preference; same characteristics as previous EOS SLRs with Picture Style control
* Black and white recording: Set via monochrome setting within Picture Styles menu
* Computer connection: USB 2.0 Hi-speed, via small "B"-type USB connection
* Remote control: N3-type push-in terminal (same as EOS 20D, EOS-1D Mark II, etc.)
* Video-out: Single-pin mini-jack
* Direct Printing compatibility: PictBridge printing to compatible Canon and other brand printers
* Compatible images: JPEG, RAW, or sRAW, if they comply with DCF protocol
* Preview effects on camera's LCD: Printing effects can be previewed (includes brightness, levels, contrast, color saturation, color tone, and color balance--face brightener and red-eye correction cannot be viewed)
* Connection to printer: Via USB cable included with camera
* DPOF image marking: Compatible; images can be "tagged" while reviewing on LCD monitor
* Battery: BP-511A, BP-511, or BP-512 (rechargeable lithium-ion, same as EOS 30D) (BP-511/BP-512: 1100mAh; BP-511A: 1390mAh)
* Shooting capacity: Approximately 1100 shots (at 68 degrees F / 20 degrees C); approximately 800 shots (at 32 degrees F / 0 degrees C)
* Charger unit: Canon CB-5L or CG-580 (also can be charged with compact power adapter CA-PS400)
* AC adapter: AC adapter kit ACK-E2 (optional; consists of adapter AC-E2, and "dummy battery" DR-400)
* Battery grip (optional): Battery grip BG-E2N or BG-E2
* Date/time back-up battery: CR2016 lithium battery--coin-type; user-replaceable (estimated life 5 years)
* Body exterior material: Magnesium alloy top, front, and rear covers
* Chassis material: Polycarbonate and stainless steel
* Lens mount: EF lens mount; metal; compatible lenses: all Canon lenses for EOS cameras
* Compatible with EF-S lenses: Yes
* Custom functions: 24 custom functions, in four distinct categories; 9 entirely new custom functions
* Operating temperature range: 32 degrees to 104 degrees F, at 85% or lower humidity (0 degrees to 40 degrees C)
* Dimensions (W x H x D): 5.7 x 4.2 x 2.9 inches (145.5 x 108 x 73.5 millimeters), very slightly larger than EOS 30D
* Weight (without battery or CF card): 26.1 ounces (740 grams), approximately 1.4 ounces (40 grams) heavier than EOS 30D
what else do you expect? outside of a 1.3x crop, weathersealing & a 12MP sensor I dont think we could ask for much more, although I dont see anything listed on their site yet about ethernet capability but I hope thats an oversight since amazon listed it
I hope the new AF system works better than the Mark III though :)
I cant wait to see how well the digic III does with noise at 1600 /3200 iso
its official nowhttp://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=139&modelid=15653
an idea of what my point and shoot rig will look like.
will convert to a DSLR rig if all goes well. they are 150lb magnets.
any ideas? comments?
I always wondered, why are the Nikon Cameras always so much more expensive than the Cannons that have the same features?
