I need to locate two wires for a Remote Start/Alarm setup that I plan on doing tomorrow, the Clutch wire (to trick the car into thinking the clutch is engaged to start the car) and a hood pin wire. So far for the past 24 hours I have seen hood pin listed in wiring lists, but no wire color associated with it (seemingly none existent) and nothing for the clutch. Any help would be greatly appreciated as the people at Zenesis couldn't locate it either when I called to confirm all the needed components that I would have to hook up for the car:
2003 MP5 5spd
So far this is all that I can locate from the12volt.com:
DIRECTWIRE™ WIRING INFORMATION - MAZDA / PROTEGE5 / 2002 / Remote Start
[PRINT THIS PAGE]
12volts black/white, black + ignition harness
Starter black/blue + ignition harness
Second Starter
Ignition blue + ignition harness
Second Ignition black/red + ignition harness
Third Ignition
Accessory black/white + ignition harness
Second Accessory
Keysense
Power Lock lt green/red - module high in driver kick
Notes: This is a one wire system, must use relays. Lock requires negative trigger through a 1.5K resistor, Unlock requires a negative trigger to the same wire.
Power Unlock same wire
Lock Motor red door lock relays
Notes: The door lock relays are located to the drivers side of the brake pedal.
Unlock Motor blue door lock relays
Parking Lights+ lt green/black drivers kick panel
Parking Lights- brown headlight switch
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger black/blue - drivers kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin red/green - at light in trunk
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer purple/white diagnostic connector
Notes: The diagnostic connector is in driver side rear corner of the engine compartment. Can also find tach in pin 48 of the ECM.
Wait to start
Brake Wire green/yellow + brake switch
Parking Brake
Horn Trigger black/red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Notes:
2003 MP5 5spd
[PRINT THIS PAGE]
Second Starter
Third Ignition
Second Accessory
Keysense
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
No Type:
N/A
Part #: N/A
Notes:
Yes Type:
Multiplex
Part #: 456LW
Notes:
