Any Idea where I can obtain a dual zone climate wiring harness?
CalAtt
I have all the parts I will need for my summertime project of converting my Manual A/C to Dual Zone this summer on my 2014 Mazda 3 except the wiring Harness, Does anyone have a clue where I could find one online? Or at least the part #?
Any help would be appreciated,
So far, I have to replace or add the following parts, keep in mind that the Housing assembly and blend doors themselves are automatically set up for Dual Zone, I took some pictures and it seems it has all the moving parts for the Dual Zone Climate control, minus the actual electronic controls themselves, You would have to unlink the Driver + Passenger Blend Doors, but I'm sure it's doable with the current housing/setup
https://imgur.com/a/59nE8Ik
Replace: BHS2-61-A30 (Manual Link Assembly) with KD47-61-A30 (Auto Link Assembly) + KF06-61-A60 (Auto Passenger Side Electronic Airflow Mode Actuator) $75.70
Replace: BHS2-61-A20A (Manual Driver Side Airflow Mode Link Assembly) with KD47-61-A20 (Auto Driver Side Airflow Mode Link Assembly) $17.06
Add: KF06-61-A60 (Passenger Side Blend Door Actuator) $51.25
Add : KD47-61-A70 ( Driver Side Blend Door Actuator) $51.25
Add : KD47-61-J70 (Passenger Side Temperature Aspirator + GHR1-61-756 (Passenger Side Temperature Aspirator Hose) $21.77
Add: BBM5-61-751A (Sunload Sensor) $29.04
Add: BHS2-61-765 (Resistor) $128.70
Now I'm just missing the wiring harness that connects all the Actuators + Sunload/Temperature sensors to the Main Control.
Like I said, any help is much appreciated!
For reference I found most of the parts needed in the Service Manual and https://www.mazdapartswebstore.com/v-2014-mazda-3--i-touring--2-0l-l4-gas/hvac--controls
