another bolt pattern question
Jessed87
Ok, im looking to buy some rims. I have them all picked out and my tires as well. I know our bolt pattern is 5x114.3. Only problem is there are 2 bolt patterns for the ms3 listed on this website so it is confusing me. The sizes are
first---> 5x100 - 5x4.5/114.3 45
second---> 5x4.5/114.3 - 5x112 45
which one of these is the correct pattern for the ms3?
The MS3 and most other mazdas are 5x4.5 or 5x114.3 (which is the same thing; inches vs. mm). The other measurements are different bolt patterns, like if a wheel is drilled for two different bolt patterns. Just look for the numbers above, the right offset (search for it) and a bore of 67.1 and you should be OK.
Both wheels will fit as long as the hub bores are at least 67.1. They're both universal 5 lug, so it's up to you. If you ever sell the wheels, you might want to get the one that's more common, so you have more potential buyers. I know the wrx uses 5x100. I'm not sure if 5x112 are volkswagens? Good luck.
