- Denver, CO
I thought Sport models were 60/40 splits.
Sent from my XT1585 using Tapatalk
Yea, apparently. I wouldn't guess how the seats fold would be part of a trim level.
Yep Australian 2017 CX-5 gets more cargo space with the rear seats up comparing to thier 2016 CX-5, but it has only about a half of the space than ours!Huh? How? Less leg room in the back seat?Over here the 17 has more cargo space with the rear seats up
Your cargo room volume VDA (litres) is based on rear seats up and to tonneau cover. Different way of calculation because you guys get free factory cargo cover which apparently sits a bit higher in 2017 than 2016's.We have 442L now, previous was 403L
Mazda CX-5 2017 and 2016.5 US/NA Spec Comparison
Noticeable differences are 187 hp @ 6,000 rpm vs. 184 hp @ 5,700 rpm; and the maximum torque 185 lb-ft for 2017 CX-5 AWD is occurred at higher RPM than FWD.
[table="width: 720, class: grid"]
[tr]
[td]MAZDA CX-5
SkyActiv-G 2.5L[/td]
[td]2017[/td]
[td]2016[/td]
[/tr]
[tr]
[td]Horsepower SAE (hp)[/td]
[td]187 @ 6,000 rpm[/td]
[td]184 @ 5,700 rpm[/td]
[/tr]
[tr]
[td]Torque SAE (lb-ft)[/td]
[td]185 @ 3,250 rpm - FWD
185 @ 4,000 rpm - AWD[/td]
[td]185 @ 3,250 rpm[/td]
[/tr]
[tr]
[td]Gear Ratios AT1)[/td]
[td]3.552/2.022/1.452/1.000/0.708/0.599[/td]
[/tr]
[tr]
[td]Reverse1)[/td]
[td]3.893[/td]
[td]3.893[/td]
[/tr]
[tr]
[td]Final Drive1)[/td]
[td]4.325 - FWD
4.624 - AWD[/td]
[td]4.325 - FWD
4.624 - AWD[/td]
[/tr]
[tr]
[td]Wheelbase (in)[/td]
[td]106.2[/td]
[td]106.3[/td]
[/tr]
[tr]
[td]Overall L/W/H (in)[/td]
[td]179.1 / 72.5 / 66.1[/td]
[td]178.7 / 72.4 / 67.3[/td]
[/tr]
[tr]
[td]Track F/R (in)[/td]
[td]62.8 / 62.8[/td]
[td]62.4 / 62.5[/td]
[/tr]
[tr]
[td]Turning Circle (ft)[/td]
[td]36.0[/td]
[td]36.7[/td]
[/tr]
[tr]
[td]Ground Clearance (in)[/td]
[td]7.6[/td]
[td]8.5[/td]
[/tr]
[tr]
[td]Towing Capacity (lb)[/td]
[td]2,000[/td]
[td]2,000[/td]
[/tr]
[tr]
[td]Total Curb Weight (lb)[/td]
[td]3,527 - FWD
3,655 - AWD[/td]
[td]3,433 - FWD
3,589 - AWD[/td]
[/tr]
[tr]
[td]EPA-estimated MPG
(combined/city/hwy)[/td]
[td]27 / 24 / 31 - FWD
26 / 23 / 29 - AWD[/td]
[td]29 / 26 / 33 - FWD
26 / 24 / 30 - AWD[/td]
[/tr]
[tr]
[td]Headroom F/R (in)[/td]
[td]39.7 / 39.0
39.3 / 39.0 - w/Moonroof[/td]
[td]40.1 / 39.0
39.0 / 39.0 - w/Moonroof[/td]
[/tr]
[tr]
[td]Legroom F/R (in)[/td]
[td]41.0 / 39.6[/td]
[td]41.0 / 39.3[/td]
[/tr]
[tr]
[td]Shoulder Room F/R (in)[/td]
[td]57.1 / 54.8[/td]
[td]57.5 / 55.5[/td]
[/tr]
[tr]
[td]Hip Room F/R (in)[/td]
[td]55.2 / 55.3[/td]
[td]55.2 / 53.7[/td]
[/tr]
[tr]
[td]Cargo Volume (cu ft)[/td]
[td]30.9 - 2nd-row Seatback Up
59.6 - 2nd-row Seatback Down[/td]
[td]34.1 - 2nd-row Seatback Up
65.4 - 2nd-row Seatback Down[/td]
[/tr]
[/table]
That 39-liter phantom volume increase of yours is the result of the raised position of cargo cover, but the true cargo volume from floor to ceiling has actually decreased by 10% - 3.2 cu-ft (91 liters) with the 2nd-row seatback up which is pretty significant to me.Indeed it is VDA and the point has been made by reviewers here that the space has increased which is a good thing
No way to fix it unless Mazda changes the body design making it looks like the Honda CR-V. 2nd-gen CX-9 has the same issue.Dang that is disappointing to see the cargo volume drop like that. I hope they fix that.
You can call it phantom increase if you want but an increase is an increase for us. The size is still adequate and for me it should be enough. Yes it's smaller than my 6 but the opening cavity is greater in the CX-5 than the 6 and I don't have to bend down and inside the cargo area to retrieve items.That 39-liter phantom volume increase of yours is the result of the raised position of cargo cover, but the true cargo volume from floor to ceiling has actually decreased by 10% - 3.2 cu-ft (91 liters) with the 2nd-row seatback up which is pretty significant to me.
Bit more space for rear passengersI know there are some body style changes from 2016 to 2017, but its mostly the same platform. What did they do to lose that space?
I bllieve the reason why cargo volume on 2017 CX-5 is about 10% less than 2016 is because 2017 loses more height than ground clearance, and the cargo floor is a bit higher than previous gen to make the whole floor a bit flatter (but still not 100% flat) when the rear seat-backs are folded down.I know there are some body style changes from 2016 to 2017, but its mostly the same platform. What did they do to lose that space?
That's debatable as 2017 has less shoulder room for rear passengers.Bit more space for rear passengers
The reviews here have said more space. Not massive but still moreThat's debatable as 2017 has less shoulder room for rear passengers.
But the specs don't lie ⋯The reviews here have said more space. Not massive but still more
