I would power the fronts off an amp and use the head unit to power the rear speakers. I did that in my sedan and ended up unhooking the rear speakers because they did not sound good at all compared to the focals. I have heard some boston stuff and it to sounds good. You will not like the sound of the rear speakers compared to the bostons. The rear speakers will only hold you down. like servoeyes said the music comes from the front. I only have front speakers and it sounds great. plus when I powered my rear speakers off the deck they could not even handle that very well let alone power from an amp that is powerful enough to power the bostons.
The one option is to get one of the amps they are making specifically for rear fill. JL has the 500/5 that has 100Wrms to the front and 25Wrms for the rear fill and a 250Wrms sub output. That would work if you have a sub that does not require alot of power. I personally have the 300/2 which powers my fronts and that is it. The 2 channel is a little cheaper than the four.
I would not get an amp for the rear speakers. just my advice. listen to some music in your car with the rear speakers up loud, the speakers just as fill, and with the speakers off. That will help you tell some but you have to remember the bostons are going to be way better than the stock speakers. good luck
