Amp/sub help!!!!!!
Army248
09 Mazdaspeed 3 GT
Ok so I have a loc hooked up to the Bose amp under the driver seat and everything ran to the amp and my amp cuts in and out and won't stay on and sometimes it will stay on at a very very low volume but as soon as I turn it up its back off ...I'm lost please please help!!!
what do you mean hooked up to the bose amp?
the connector has 17 pins, 8 in, 8 out, and a blue amp turn on
the 8 in are low level, so a LOC would be a bad idea
the 8 out are speaker level, but have all the bose sig proc your trying to avoid,.. a bad idea
the other connector has +12, grnd, and the leads to the rich bass sys tapping them to feed a sub amp is a bad idea since the also have a ton of sig processing
now, you get some RCA's on those 8input leads, and plug them into your aftermarket amp and your in buisness
its internal the amp is fried just put in another one or run a really amp aftermarket one hope this helps
Similar Threads and Articles
