amp questions.
Yeah, most subs will loosen a bit after a few hours of playing time. The surround and spider are a bit stiff when new. You can either play music for a few hours or play a 45-60Hz test tone through it for a little while. It also depends on the suspension material and temperature. Rubber surrounds in cold will obviously be stiffer than when it is warm.
The box size plays a big part as well. Manufacturers usually recommend a range of box sizes, but I find most recommendations to be a bit on the small side. Smaller boxes will play tighter and fit more easily, but you may want a larger box for more output. Plus, each sub's specs can help determine whether it is more suited for a ported or sealed box. A good program for box building is WinISD. Once you enter the driver's T/S parameters, it will recommend a box type and size. You can tweak it for the sound you want from there. The basic program is free: http://www.linearteam.dk/default.aspx?pageid=winisd
yeah image dynamics sent me a piece of paper with size recomendations and they also put in all caps "SEALED ENCLOSURES ARE VERY STRONGLY SUGGGESTED FOR MOST LISTENERS" i'm just hoping it loosens up and sounds as nice as my audiobahn.
UPDATE: The sub has definatley loostened up and sounds great. I had to turn the amp back down to compensate for the sub getting louder as it broke in.
That's good. I'd be worried about your hearing if you came to the conclusion that the Audiobahn sounded better than the ID.
