tsunami said:
how does a capacitor reduce noice??? 10 micro farads is some small stuff but where would you put that with rca to reduce noise...??
A capacitor by nature passes AC and blocks DC. It also stores a charge - which is the feature we take advantage of when using a large one on an amps' power wire.
If you attach the + of the cap to the remote wire and the - of the cap to ground, it will shunt the very small induced AC (noise) to ground. The uF value of the cap to use depends on the load and the frequency. Since the induced noise has very little sourcing current and the frequency is fairly high, a small cap is all that is needed. This cap is a decent example:
http://www.radioshack.com/product.asp?catalog_name=CTLG&product_id=272-1013 An even smaller cap may be necessary (1uF or even lower). Again it depends on the amount of sourcing current of the noise and the "load".
You wouldn't want to do this on an RCA signal wire since you'd end up blocking or shunting (depending on the configuration of the cap) the signal! If you have noise on the RCA itself, they must be running alongside a fairly heavy current wire somewhere. You can either move the wire or shield it at the problem area.
Another way to supress noise is to use an inductor (choke) in series with the power. An inductor is basically just a coil of wire wrapped around a core (usually air or ferrite). An inducator passes DC, but blocks AC by using back EMF. The mH value to use depends on the load and the frequency. SInce the load is in series with the inductor, the size of the wire in an inductor depends on the current the load needs. Sometimes simply getting a ferrite choke core (
http://www.radioshack.com/product.asp?catalog_name=CTLG&product_id=273-105) and wrapping the remote wire through it a few times is enough to eliminate the noise.
Those noise supressors on the market are basically just a capacitor and inductor network wrapped in a small box. Actually, this is basically a low pass crossover meant to pass very low AC (to the point of being DC).
Speaking of crossovers, the principles explained above is what makes them work. A high-pass xover uses an inductor in series and then a cap in parallel to the load. The inductor blocks some AC and the cap shunts the rest. Since the frequency determines the impedance of the xover network, the output is a slope - 6db for a single component (inductor or cap), 12 db when using both of them, and so on. Reverse the order of components for a low pass xover.
Sorry about the long explanation and the slight deviation from the topic on hand... I do tend to get carried away.
