Am I stupid or what? The Nav audio and radio audio cannot be tied together!
michaelveloz
2016 CX5 GT
On my 2016 GT I must be missing something very obvious.
I can't seem to figure out how to control the audio of the radio and the navigation separately.
If I use the audio button to turn up the Navigation, the radio plays louder. If I turn down the audio button, both the radio and the navigation get softer. If I use the "mute" button, both get muted.
Surely there must be a way to turn off the blasted radio, or mute it, while still being able to hear the Navigation??
Please tell me what I'm overlooking :0
Thanks
Michael
You can change the nav volume independently when the nav is talking.
Or in the settings you can set the nav volume.
Thanks, but how do you change the nav volume independently?
I do see a setting for nav volume in the Settings, but surely I don't have to dig through settings everytime I might want to lower and raise the Nav volume? And have you discovered a way to mute the radio so you
Thanks again
Michael.
When the NAV speaks you can raise or lower the volume settings. It will only affect the NAV volume.
Thanks again
Michael.
You have to wait until the navigation is speaking or making a noise, then if you use the regular volume knob it will change the navigation volume only while the navigation is speaking and for a few seconds after.
Thanks, that helps.
But let's say I have the volume turned way down, or event muted, because I don't want to hear the radio. And then I start NAV, should I be able to hear anything from NAV in that case?
Thanks again
Michael
If you have the nav volume turned to 0 the only way to get the volume back is through the settings menu.
If you need the nav volume to be louder than the radio you have to turn down the
radio volume, then when the nav speaks turn up the nav.
You can tun the radio all the way down and still have nav voice. I'm not sure if you mute it though.
