im not really good at how-tos so it goes...you need
3" light strap hinges from lowes or any hardware stores
4 short screws
2 L type screws, long enough to hold up the hood at where you bolt the hood on...this sucks, ill just show you pics of the set up and ill try and answer questions...
you need at least 3 people to help you out, do at your own risk
1. take cf hood off
2. screw one side of the strap hinge on where you bolt the hood on
3. put hood back on, bolt the 1 12mm bolt on the bottom on where you bolt the on
4. with the other side of the strap hinge, screw two screws into the hood
5. once youre done with that, you can unbolt that 12mm bolt and use the hinge to lift up the hood like in my sig...be careful when you do this the ends of your hood might get caught with the front quarter panels where your hood meets the car
heres the tricky part, propping up the hood for the show, if you just put some type of prop in front by the grill, the weight of the hood will force the hood down and that will **** up your hood, what i did was that i drilled a hole in the side where the hood gets bolted on so it gets stabilized at the hinges and the prop up front will hold up its end...here are the pics, hopefully this helps...
