Alignment Specs?
JOSER_SPEED6
2014 Mazda 6 Touring
I've looked online and also through other post and have not found the factory alignment specs for the CX-9. Does anyone have them or know where they are?
I'm installing new wheels this weekend and am going to get it aligned while I'm at it. The dealer is charging me $100+ to get it aligned and warned me about taking it to an independent shop since "they'll mess it up, since the CX-9 have negative camber in the rear". $100 just seems like alot to me for an alignment job.
Thanks for the info
For AWD rear wheels:
Total toe-in (mm {in}) for 20 inch wheel: 1.4 {0.055} or 009′018′
Camber angle Tolerance 1, Fuel gauge indication (Empty,1/4,1/2,3/4,Full) - -027′; -028′; -030′; -031′; -033′
Thrust angle 0
If you register as a owner on mymazda.com, there are many goodies including factory coupons that are good at all dealers.
I just checked, 4-wheel alignment is $89.99.
My dealer wanted $34.99 for an alignment when I was just in for 15K service. The put it on the rack, checked it out and said it didn't need it so they didn't charge me. I watched them do it. about 1/2 hour of labor right there for free. I have an excellent dealer.
Thrust angle 0
Thanks for the info. I guess I should have specified I have a FWD, sorry about that. Where did you come accross this info?
For FWD, Camber is (based on gas volume), -026′; -027′; -029′; -030′; -032′
It's from online mazda service manual.
