- MP5T / 944
Their number does seem high and the reason I ask was the size of the core is small. I believe that the number is accurate. I am interested to hear about your results. I went with a huge FMIC because I was worried about heastoak and pressure drop. I knew that I would be trading throttle response for it but I honestly don't think that the lost time in charging the volume is much diferent. Taking the compressor flowrate vs. the volume of the intake, if calculated works out to be 0.17 seconds from a dead idle for my setup, and as everyone knows... I have alot of intake, but most of it is far away from heat.terbow said:i agree, its heavy but for what i do with the car i think its the best solution for me. plus i like to be different.i dont know how to calculate pressure drop but on the spearcos site it says its .15psi @ 30psi (seems like a high psi but it says its performance data is at 30psi so i dunno).
Again... Awesome idea, you are totally correct with your statement that it is a much more effecient design. It will hold constant temperatures much better than an FMIC.
