Air Pressure reminder...
ROBSTOY
Mazdaspeed 3
I remembered what I had learned from the forums a while back...when you get a new car, check the tire pressure!! Mine were all inflated to 40 psi!! It felt like I was riding on top of the tires (if that makes sense). (direct)
speaking of tire pressure, my 2010 3 GT Touring has the presssure sensors on it and I was wondering if these sensors are specific to mazda rims and will they work with aftermarket rims ??
i believe the rims must be compatible with TPMS or else you won't get to take advantage of said system. they are not for mazda rims only.
I took your advice and decided to check my pressure...would you belive it was 45 psi...........W.T.F
Crazy huh!!! I believe they over-inflate the tires for the boat trip over. You would think the dealer would check them.....
somone did something to mine at the dealer before i picked it up, because pressures ranged from 25 to 40 and one valve stem cap was missing.
Similar Threads and Articles
