Air impact wrench with air ratchet AND sony speakers!!!
Status
Not open for further replies.
03 protege dx 5spd
two sony speakers (model XS-E1311)
and an air impact wrench and ratchet set. ratchet is 3/8" drive. impact is 1/2" drive. impact used once and ratchet never used. comes with sockets (size 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, and 1").
and an air impact wrench and ratchet set. both 3/8" drive. impact used once and ratchet never used. comes with sockets (size 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, and 1").
What size are those speakers?
prices?
you MIGHT need to get a metal plate depending on where you use them, but those are cheap and if you good with fabing stuff you could do it yourself.
to be honest...no idea right now. when i used it, it seemed like a lot but idk... trying to find out right now :)
it is item 92280 you can look? i couldnt find anything.
[FONT=arial, sans-serif]13 PIECE SET WITH CARRYING CASE[/FONT]
[FONT=arial, sans-serif]Includes reversible 3/8" ratchet, reversible1/2" impact wrench, and 10 piece impact socket set all packed in a blow mold case. [/FONT]
  • [FONT=arial, sans-serif]
  • 3/8" air ratchet wrench for fast action on automotive fasteners
  • Reversible 1/2" impact wrench delivers 230 powerful ft. lbs. of torque
  • 1/2" socket set includes sizes: 7/16" through 1" by 16ths and a 3/8" to 1/2" adapter. Chrome vanadium steel construction and lifetime warranty[/FONT]
[FONT=arial, sans-serif]Reversible 3/8'' Ratchet: Air pressure: 90 PSI, Air consumption: 4 CFM, Maximum torque (ft. lbs.): 50, Speed: 150 RPM, Inlet: 1/4"-18 NPT, Length: 10-1/8"; Reversible 1/2'' Impact Wrench; Air pressure: 90; Avg. Air Consumption: 4 CFM; Bolt capacity: 1/2"; Maximum torque (ft. lbs.): 230; Speed: 7000 RPM; Reversible; Inlet: 1/4" NPT; Length: 7-1/4"; Weight: 5 lbs.[/FONT]
not really sure...trying to figure out if i want to get rid of it or not...and it really depends on the dealership and how bad they want to get rid of the ms6's the got left. also gotta talk to the parents to get them to cosign on it.
oh.s***. so you're not just straight up selling ok.:(
Status
