I tried searching for this but had no luck.
My a/c is messed up(if you couldn't tell by the subject!)... The 'ac' light only comes on at the '1' setting and in between the 4 and 5 settings(which takes a while to accomplish...it's touchy). I have taken it to the dealer, and they said that the previous owner of the car messed it up when they installed the aftermarket headunit. They said they broke something by forcing it(the headunit) in. The dealer would not fix it under warranty. Also, the heat does not work... they said it was the same problem.
Now I am wondering what i can do, if i can fix this myself, or if i can order a new ac console and install that?
Anyone had a similar problem?
