i think i might get to join this thread after this weekend haha
Same here... 17x8 +35 coming soon...
Perfect.
Good stuff! My Current setup is 17x9 +35 in front and 17x9 +35, +25mm spacer = 17x9 +10 in the rear. The rear has a -7 camber and the front has about -3. My plans later are to run 10's in the rear with a different setup. =D
With a -3 camber it had a credit card clearance.
lol, nice. So you could probably run a 17x10 +20 and clear the strut? I feel like my math is wrong... lol
You know... I really don't know... I have not measured the clearence of the current setup. I'll try to do that soon. I'm really eager to find out myself.
There seems to be a large disparity between the 2 measurements above. Unless there is over a 10mm difference between the front and rear...
Actually, come to think of it, fd's are a 16x8 +50 and they clear the strut... I think w/ 8" wheel +50 offset is about as high as you can go, tho.
yah cuz if your rear is a +10 you must have a lot of room until u hit your strut
i did my math for the fronts plus a test fit and a 17x8 +45 is the highest you can go until you hit the strut
thats a 17x9 +20 - perfect fitment btw
and a 17x10 -5
just to clear the strut in the front with a 17
yeah the clearance issue is on the spindle mount on the stock struts as well. 3mm spacers clear up the issue.I agree with wagon, 50 is really high. I have my 17x9 +35 with BC coilover and that has a credit card clearance. And if i made that into a 8" it would be a 17x8 +47? With no camber and fully aligned.
