Aggressive fitment anyone?!
I took a few. Heres two quick shots. hung...U the man!
That's sexy! (2thumbs)
I feel like it may be a touch too much camber in the rear, tho... Idk, seems to have a bit of room for clearance still. ;)
I wanna know about that rear fender job, WOW! It looks pulled to the max but done extremely good.
Does look extremely good but looks like it's been repainted or something as you can see a line....or is it just my eyes? Other than that the front is hella perfect for my taste but the rear is a bit too much camber for me. So...what's the wheel spec??
So,after all the reading i am thinking of changing my tires to 205/40 or 215/40
i just want to make sure it will not rub since i am putting MSP springs,i understand the drop is only .75"
Very annoyed of all the rubbing with the current tires .
No, you won't rub.
Nonetheless i will roll the fenders,just want to make sure before i spend money on new tires.
whats the offset on the rims?
I assumed oem wheels. Factory specs on MSP are 215/45/17, right?
Argie - you're not gonna rub, but you can roll your fenders if you want. You're not even close to rubbing... I was dropped almost 2" past where MSP springs would sit and never rubbed with 215/45/17. Then I got 15mm spacers, and that changed the whole story.
