everyone says the same thing![]()
Haha, fair enough.
this, in my opinion, is perfect fittmentwoot woot!
Stance shot...
a lot has changed since this pic tho,
bout to do a photo shoot this week
Protege03ak46, turbo that thing. But the look is sick!! Ive seen you pics on stanceworks.
Do you rub on the strut side or the fender side because I've heard multiple times that the sedans have more clearance then the wagons... and ya I'm not nearly as low as you are, my suspension may or may not be stiffer (don't know what you run), and I think I'm running more camber then you back there (-1.5*)i have 205/50/17's on my 5zigens, there +48 on a 7.5" and they rub, alot
but i dont think u are as low so its hard to say
i agree, his in the only stanced p5 i like
his is also the only non-lip P5 i like
My setup: 17x8 +38 with 225/45 in front & 215/45 in rear. Front has no rubs, rear is rolled/pulled and still rubs a little if I'm driving hard or going through uneven roads... Lowered on Tokico Illuminas & RS* R Race Springs. Camber is around -1
The sedans have roughly 2mm more clearance in the rear than the wagons. Front should be the same. Rear is where you will have more issues fitting the wheels, tho. Personally, 17x8 +35 is near perfect fitment on the Protege, unless you want a lot of poke...
Just fyi, 17x8 +35 is equivalent to 17x7 +23 or 17x7.5 +29 in terms of being flush with the fender.
If you click the link to my mod list in my sig, there are pics of my setup.
How much rubber? Them tires seem pretty meaty
I hadn't measured exactly. There was plenty of room with 17x8 +45, I know that. And now @ +38, there's even more.
Trailing arm isn't an issue, either.
