Aftermarket turbo not lining up with the downpipe
I'm not really concerned about about the pope dp looking ugly because of a modified bolt hole no one will see.. Got a burr from grainger, so hopefully I can grind some metal in the morning.
slot that hole, it's not going to cause a leak but leaving that bolt out will give you more likelyhood of a leak....and just slotting that one hole won't hurt it if you ever go back to the stock turbo either....
