I've done some reading on the forums, and most recommend only genuine thermostats due to poor history with aftermarket thermostats at Autozone, etc. However, I stumbled upon this and wondering if anyone has any experience with this company/part. Currently, onlinemazdaparts.com has the genuine part at $44.95 plus 7.50 shipping. Total: $52.45. So you'd save $20 with the Stant thermostat. Worth it?
From Amazon:
Stant 48728 XACTStat 180 Degrees Fahrenheit Thermostat
Price: $32.75 & this item ships for FREE with Super Saver Shipping.
https://www.amazon.com (commissions earned)
Stant’s XACTStat thermostats are designed for customers that demand the exact OEM thermostat as a replacement product. XACTStat thermostats include all the features that make them original equipment equivalent parts. Jiggle pins and check valves for air venting, integral seals and integrated water outlet housings. Some even have ports for attaching coolant temperature sensors. So if you want thermostats that are EXACTLY the same as the original part, order XACTStat thermostats from Stant.[/INDENT]
From Amazon:
- Designed for customers that demand the exact OEM thermostat
- Thermostats include all the features that make them original equipment equivalent parts
- OE Type Thermostat Water Outlet Assembly with Check Valve, Seal
- This thermostat is Mazda OE #LF5015170C and LF7015170
