joe_rocket65
- 2010 3s Sport GS 2.5 6m/t
Doesn't seem anyone has tried aftermarket springs (ie. Eibach Prokit) with OEM MS3 shocks/struts. I'm eventually going to upgrade the springs and want a mild/mod drop and will most likely go with the Eibach Prokit along with rear camber kit. This will leave the springs underdamped with the OEM MZ3 shocks/struts. I'll probably drive it until I either don't want to put up with it or the shocks wear out whichever comes first lol. Since the MS3 has stiffer springs i'm assuming the shocks/struts are set up with increased damping so will using the MS3 shock/struts with aftermarket springs properly balance things out or will I have to go with another setup such as Koni Yellows.
