Can Pauter rods be installed in the factory pistons?
Can this Rods be mounted, by the bottom, without removing the engine from the car?
I have seen other mazdas here in PR that has been change the rods by the bottom of the engine, without removing the engine from the car, or disasembling the engine.
It all depends if the piston pin can be mounted without a press.
If this can be done we can resolve the rod-snaping sindrome at a lower cost than a full build up.
For me down time is very important, and if this can be done it will be just a thing of a day or two.
