Fluttering under low boost is perfectly normal and wanted to be honest. If you tune your BPV to where there is no flutter it will be too soft and not hold boost. If too much then you will get Surge which is not wanted. Flutter at mild boost is good and at full boost you should just get the blow off without any flutter.
bpv/bov sounds change with the inlet. yes. if its more of a flutter sound then go over an check you're couplers and clamps, it could be compressor surge if not installed properly.
Does that apply to all BOVs? I have a Turbosmart Ultimate and it doesn't flutter and low boost. Can you tell me the exact boost number where you'd normally release and get the flutter. I'n just trying to see if mine is set to soft.
mine is a little under 3/16ths
If you had a leak it would run like POO beleive me. I half-assed the first install of my first inlet pipe and it was very noticable. My Forge doesn't sound lek it should either. No "ping"![]()
