AFR reading only 14.8
LV Tunerz
07 MS6 GT
as the title says my AFR only reads 14.8 at all times , doesnt that mean that that is the worst it can get ????
um no.... stoich is 14.7 so that is like perfect for idle and light cruise. at wot your afr should drop down into 11s and 10s.
lol the gauge is deff. not working properly. its seems like it is not getting a signal
now i have a CEL code stating that my O2's are not sending signal ??? i have them all screwed in but i just dont know why it would not send a signal ??? Could running to rich for awhile blow them out ???
i sure hope you didn't try and tap into your first 02 sensor to try and get the signal from it, because if you did you just ruined a 400 sensor. running rich for a while wont blow them out. i doubt you ran richer than when the vehicle was when it was stock.
i would check all your wires and make sure none are broken.
you might also want to consider checking your fuses. what are you using to read your AFR?
did you unhook your O2 sensors for any reason from the connectors? i would check all the wires. the connectors are under where the turbo inlet is so you would hvae to move the battery and tray to get to them.
