SpeedAdiction20
- 2003 MAZDASPEED Protege
the overpressure setting is just when it tells the car to go into closed loop??(I said open loop before, but I guess that is not what it is, it doesn't really matter) but the point is that it forces the car to start using the map it has for in boost fuel control, and therefore when the ssafc starts being useful, to put it simply, after having it set to -1 for a while, I liked it set to what I have it at now, which is .2, that means that the ssafc will start adjusting fuel pretty much right when you get into boost and hit .2 (and on the fuel maps, the cell for that is .5, not 0psi) but I changed it because when I do highway driving I didn't want the car to switch unless I was actually in boost, and sometimes when I'm going up slight inclines the boost will stay right at 0psi or just under, it just prevents the fuel maps from changing back and forth while driving, just makes it easy IMO,
I would set it to .2 or .5 or something like so that it will switch early and you don't have that hic-up when the ECU changes loops that people talk about, (you will notice it eventually, but it's just easier to take our word for it now and look for it later, makes tuning smoother)
