Advice needed on MSP3 stock Wheels&Tires
funkyman
Mazda MS3 Red with NAV
Hi i was wondering,to me the stock rear tire looks rather narrow for the cars appearance and stance etc.Do you think the stock wheel can accomodate a 245/45/18 tire i the rear without protruding from the fenders and without fitment issues on the wheel itself as it is only a 7.5" width,basically can it handel a 245 18" tire in the rear with a 7.5" stock wheel width.Also with staggered fitment can the difference in tire width be as much as 30cms like can i leave the stock front at 215 and put a 245 in the rear,would that affect handling adversley
245 in the rear will not clear the fenders, or if the offsets were high enough to tuck, it would rub the struts.
If I understand you correctly, you want to put big tires on the back and smaller ones on the front on a FWD car? Weird!
Mazda has done an admirable job of creating a suspension on this car that is quite balanced. If you do this, you will make the car push which would be unfortunate.
