Advice/Grinding at takeoff (p5 AT)
So my p5 will make a grinding noise and feel when i accelerate hard from a dead stop. This only happens at dead stop. I have tried it rolling with the trans in 1st and it does not happen. Does this sound like a problem with 1st gear or something with the exhaust. I know there is a history of EGR valve problems but im not sure what the effects of carbon build up in the EGR does.
egr won't result in grinding, check the atf fluid and see if it's still good (redish color) if not drain and flush, and look for broken bits.
The ATF is pretty dark on the dipstick. I bought this car used and do not have many receipts unfortunately. It is at 65k so probably due for a change. how difficult is it on a p5? I am not an expert mechanic but not an idiot either, i have done basic things like oil, brakes, and such. should i do this myself and save money just take it to the mechanic?
