Adj. cam gear with J.Spec intake cam?
ha. think in the range of 2-5 hp.
dont believe everything you read from the people trying to sell you stuff.
OK thanx!
Then Corksport must lie......
J-SPEC 2.0 FS-ZE intake camshaft (1.8, 2.0)
<TABLE cellSpacing=0 cellPadding=0 width=90 align=left border=0><TBODY><TR><TD align=middle>
</TD></TR><TR><TD align=middle><SMALL>View Larger Image</SMALL></TD></TR></TBODY></TABLE>
The J-Spec intake camshaft is the OEM piece from Mazda in the 170hp FS-ZE engine. The camshaft has added 10-12 whp on stock FS engines.
Also show to be very effective on turbocharged models.
i just installed the J-spec cam two weeks ago, and my high rpms are much more impressive. No adj cam gears, dont need them! I cant tell exactly whats giving me all the gains though, i did the cam, unorthodox pulley, flywheel, clutch, stainless clutch line, redline fluid, motor mounts, and header at the same time. But after all that, its definately a different car! If you can same up, it makes a pretty strong all motor car.
Guys with early FS-DEs in Probes and 626s got that kind of power with OBDI. OBDII will learn around it.
If you do a search you will find my dyno charts w/ the J-spec intake cam and Mazdaspeed exhaust cam. Not very impressive if you ask me... Yet that is....
