AlbanianDude
- CX7 Custom exhaust,cold air, 2 12's double tint all around.
HI guys we are trying to add two 12's and using the stock radio and no luck with getting any sound can one of you help please.
do you have the Bose system in yours?Cx7Girl said:are you converting your stock channels to RCA lines? how are you trying to run your amps?
You need to find your Bose AMP and tap in BEFORE the signal reaches the amp. you cant really tap into the door speakers because Bose messes with the sound too much.AlbanianDude said:Trying to use the stock deck bose system with the 6 indash cd changer
Thanks man i will take it in tomorrow and see if we can get anything going.CX-7's=LOVE said:You need to find your Bose AMP and tap in BEFORE the signal reaches the amp. you cant really tap into the door speakers because Bose messes with the sound too much.
I think he is Just adding subs.Cx7Girl said:yikes, i have the sport edition cx-7 without the bose systemfrom experience, i'm a service advisor at Mazda, it would be very difficult to try and remove the dashboard and take out all of the dash speakers, and then replace them with aftermarket speakers and components. I personally would leave your speakers alone, unless you have someone who REALLY knows what thery're doing work on them. Not to discourage you AlbanianDude, but unless someone else out here has experience with removing the BOSE system and repalceing with other speakers, I would leave them alone. good luck with that, and I would be interested to find out how it turns out.
1sty said:The bose amps tend to take in a signal from the head much like any amp.
Becuase of this you can typicly tap the signal wire to the amp, which is full range, and solder RCAs to the extended wire. Then go right into any amp.
1sty said:Best option for dash speakers...disconnect them
Problem solved
CX7nCali said:Yes, but are you suggesting tapping into the signal and still having it connected to the Bose amp at the same time? It can be done, but it will lessen the already low voltage and probably introduce noise into the system. Let alone someone not doing it right and damaging the amp and not be warranted. Of course having a certified tech like yourself would lessen that chance. Then again, would a certified tech touch it with a ten foot pole since it is a factory integrated system under warranty?
Maybe Navone has a device for this application on his site. ??
Ah, heck with it, open the HU to create an optical output to be used with an Alpine C701/H701 processor.![]()
CX7nCali said:The Bose dash openings are one thing going for the CX-7, is the option to create a good soundstage with the right speakers and equipment, and not have to build kickpanels. This also means keeping it stealth.
I'd love to take the dash apart to see what kind of room there is to work with around the Bose speakers. Have you seen it yet? If so, post some photos.
Is Emailing/Calling Bose really needed for something this simple?CX7nCali said:Here ya go, this is the contact I have at Bose.
Contact her to see if there are any answers for a Subwoofer add-on.
Then post back here what you find.
She will generally go ask the techs to find a solution, if it is something they can easily suggest to the average lay person.
Patty Bolack
Service Support Specialist
Bose Automotive Systems Division
508-766-9522
Patty_Bolack@bose.com
