ABS Light
mazda3zoom
Sweetest Car Ever
Ok so im just drivin along and my ABS light just comes on. I wasnt even hittin the brake or anything. The car still stopped just fine and once i got to where i was going i looked it over and there didnt appear to be anything wrong with the brakes (no smoking or smell of brakes burning). Does anyone have any tips or stuff i should check???? Theres a fuse under the hood for it but i shouldnt have to disable the whole system.
ok found the problem. while i was under the car i noticed the front right side tire was rubbing against the ABS sensors wire and wore right through it. So after soldering and taping it back together its all fixed now.
i would still take it to the dealer and have them fix it properly. you have a warranty, you might as well use it.
What he didn't mention is that the wire was rubbing because *somebody* forgot to fasten it back up after they installed the drop springs. :D
(hand) No warranty for you!
i couldnt imagine what sorta idiot would do that....
SHHHHHHHH (braindead
also protejay5 im over 50k miles so i DONT have a warranty....
