ABS Light and E brake Light ON?
I am experiencing the same problem. I had my pads and rotors replaced not too long ago, perhaps they messed it up when they did it. Now, would a OBD II scanner tell me which side it is since I am getting the ABS light and brake light? Don't feel like replacing both for nothing
Update: I ran a OBD ii Scan and didn't get any codes.....is it possible that a generic OBD ii scanner doesn't pick up this code?
obd scanner i do not believe will pick it up......maybe a snap-on modis computer may pick it up..........do a visual inspection and check all the wires to the wheel sensor make sure none of them snapped.......the wheel sensor wires are very thin and a slight pressure can cause them to snap....check all of the wheel sensors for s**** and gigs.
You need a special scanner that reads codes for the ABS module. Some auto parts stores have this available to use, but I would call around first.
I hate that i even looked at this page last week, cause here i am now, trying to figure out wth my ABS and Ebrake light came on almost 20 hours later afteer i just did my engine swap...???
1) I checked my pads, all pads have 50% or more pad.
2) Check my resevoir - FULL
I did have to replace my front, rear, and passenger side engine mounts. I'm really happy to see MX5RACER addressing his issue - Truly, this mazda board has been a wickedly awsome assistance in my nearest time of need.
I love you guys (butthump) xo
Going to check this out after work - frig, it's raining out.
i had this problem after i took the abs fuse out, both lights were on so I put the fuse back in cuz it was gonna irritate me, I dont know why the brake light would stay on but After I put it back in all was well, dunno if this helps but might be it
ABS Conrtol Unit
I had the same problem with my mazda 6, ABS light is on, handbrake light is on, check engine light is on, speedometer is dead, milage is not counting, and sometimes the transmission light goes on, AT, and the transmission stops changing gears, it goes bizerk untill i turn of the car and start it again.
After checking the problem it seems that the whole ABS control unit with the pump has to be changed due to ubnormal readings, no sensors or anything else, just the control unit. but good luck in finding one, i searched all around and no used part and the new one costs over 1000US$ and had to be ordered from Japan.
So u wanna turn of ur ABS light, change the control unit, and take some prozac cause the price tag is gonna kill ya. (sick)
