ABS and Traction Lights keep comming on
Alexi
Whitewater Peral Mazdaspeed 6 Sport
I just had to have my hub assembly replaced at Mazda. Now everytime I go above 70mph the abs and traction control lights will come on and stay on. When I turn the car off and back on they go away and will not come on again until I go over 70mph. Also the Cruse control will not work once this happens and it feels like the awd system is disabled.
Any Ideas?
Thanks!
I'd take it back, and have them check the issue out. It might be an issue with what they did or a DOA part. I know that is the wheel bearing get bad enough or things aren't aligned properly in the knuckle it cause all sorts of ABS/ Tract control issues.
Basically what it might boil down to is the abs Sensor isn't reading something correctly, and the on board computer is put things into a safe mode to keep from breaking anything.
