ABS and TC lights on after brake pad change ?
06 LS MS6
07 BM GT (shell has been struck from the roll)
So, did the rears, no sweat except you NEED the little two pin caliper screw tool, tried to do the fronts, but was sent regular 3 pads ( more on that in another thread) so tabled that matter for another day and buttoned it up
also did the cabin filter so the bat was disconnected, and topside harnesses were off the pcb. cabin filter is more trouble than a filter should be, but not so bad
fire t up and have ABS and TC lights on
everything else seems ok, need to do a test drive, might have a bit of bleeding left, or mebbe spongy with the fresh pads in the back
any thought on the lights being on ????
NEVR MIND
Geez, take it around the block for a shake down and the lights went out 3 sec after I started moving forward
(hand)(hand)(hand)(hand)(hand)(hand)(hand)(hand)(hand)(hand)(hand)
