About Turbosmart Dual BOV
ncspeed21
08 Mazdaspeed 3
Can anybody explain to me how to adjust my BOv to full Recirculation rather than vta?! which way do i turn the knob... is it harder or softer? thanks in advance :)
In order to change the Turbosmart BOV from Dual to full recirc you must remove the horn and replace it with the cap that comes with the BOV.
That is correct you will have to use the blank plug after you remove the "horn"
The hard/soft is only to adjust the spring tension.
